I have a garage 450 feet away from the electrical service. I am figuring voltage drop. This is a storage garage with a few lights and outlets. Not totally sure what will be used in it. A vacuum cleaner? Circular saw. Maybe one day a electric heater. I understand the formula to figure it out but what values do I use. If I do a load calc on the building do I use 120 or 240 volts. Do I do both and see which one gives me a large conductor size.
Should I just assume one 20 amp 120 volt load? I get confused when there is so much unknowen. Thanks
