E eager2learn Senior Member Location Mennifee,Ca Dec 17, 2008 #1 i would like to know the formula for voltage drop single phase and three phase please
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician Dec 17, 2008 #2 Take a look here: http://www.mikeholt.com/technical.php?id=calculations/technicalcalculationformulas
T tlaidman Member Location Cleveland Ohio Dec 19, 2008 #3 formula VD= 2KLI/cm K=12.9 (constant for copper) L = length I = current CM = circular mils
Smart $ Esteemed Member Location Ohio Dec 19, 2008 #5 http://www.dolphins-software.com/voltageDrop.htm
celtic Senior Member Location NJ Dec 19, 2008 #6 Here are the "cheat sheets" Voltage Drop Voltage Drop for any voltage Minimum conductor Size for Given Voltage Drop Maximum Length for Given Voltage Drop ....all in one spot: Electrician Calculators :grin:
Z ZElectric Member Jan 8, 2009 #7 Voltage Drop Calculation Sheet Voltage Drop Calculation Sheet I put together a spread sheet that calculates for me in excel. It works great. I use it anytime long runs to a motor is required. It has save me a lot of headaches. I would attach it if I were allowed.
F Full Spool Member Jan 18, 2009 #8 VD= (2xRxIxL)/1000 VD=voltage drop R=resistance I=Amps L=Length of the run
