1964element
- Chicago
Stake ons
Sent from my E6782 using Tapatalk
That's nuts.This is pretty standard on jobs that we do without consideration of load. I think it is a crazy waste money in many cases and no one ever uses the real measured voltage in the calculation and the voltage rating of the equipment is always ignored as well. VD is the wild west in terms of understanding, implementation and enforcement.
Did I read t;he OP correctly??
12V drop at 16 A. Even if #10, that is a 350 foot run ! Or am I math dyslexic this AM ?
If there are no 400 ft runs, I'd suspect the owner is using 2 different Harbor Freight meters ?
Suggest the owner reverse the meters, then he can get a Nobel prize for a new method of power generation?
Measured along the length of the circuit.How is this distance measured?
does it continue on past 85'?
Sometimeswould say a 300' run require pulling #4 wire?
Haha. I wish that I could say that.that's about the dumbest thing I've heard in a long time.
That is easy. Try landing 500 MCM on a 100 amp breaker.You cant even land #8 on a 20A breaker.
Walmart is notorious for upsizing wires for branch circuits. Very common to see #6 or #8 spec'd for some receptacles.
All prints show it but, how often is it done.
Many big box stores have sub panels.
Smaller ones I always pull in 12.
Would never get a job if it was bid for VD
