Does anyone know if you have to calculate voltage drop for neatral conductor I have a situation where I am considering running a urd triplex cable with a reduced neutral and have calculated the voltage drop for the hot legs but will the reduced size of my neutral effect the voltage drop? Does anyone know if it is against code in massachusetts to use triplex or urd with reduced neutral?
