wwhitney
- Berkeley, CA
- Retired
I said the same thing both times (after fixing the cubic -> square error), so if it makes more sense the second time, I must not have explained it well the first time. Or perhaps you misread it the first time.Now that makes more sense.
Yes, that will work. You can also extend the method to adjust for different conductor sizes in each segment, by picking one size as the base size and multiplying the distances on the segments of other sizes by the ratio of the unit resistance on that segment to the base size unit resistance.Another way to do it that works for equally and unequally spaced is to multiply the load at each point in the run by the distance from the source. Sum the results and divide by the total load. Use the resulting distance and total load to calculate voltage drop
Cheers, Wayne
