There is, but I think the simpler basic equations are easier to remember and use when testing.Sorry for the late reply , there has to be a way to reconcile those equations with I squared x R as they both provide the same number.
E = I x R
P = E x I
to the OP, so what do you get algebraically if you substitute the first equation for E into the second equation?Sorry for the late reply , there has to be a way to reconcile those equations with I squared x R as they both provide the same number.
That's right, I'm just trying to help the OP answer his own question.There's no debate; the shortcut was given in post #2. My intent was to show why the formulae work.
Yes, but we all seem to remember the E=IxR and P=IxE since was learned pretty early in basic electric studies, and is a base for nearly everything from there on.to the OP, so what do you get algebraically if you substitute the first equation for E into the second equation?
Cheers, Wayne
Exactly. I can explain how and why the two basic ones function with actual electrical properties.Yes, but we all seem to remember the E=IxR and P=IxE since was learned pretty early in basic electric studies, and is a base for nearly everything from there on.
Certainly, and remembering those is enough, if you know how to combine them, either algebraically or computationally.Yes, but we all seem to remember the E=IxR and P=IxE since was learned pretty early in basic electric studies, and is a base for nearly everything from there on.
In this forum?!I didn't realize it would generate a lot of commentary.
We're lucky it's on track as it is.In this forum?!![]()
gar, as Tom points out, the answer the test is looking for has been given, there is no need to confuse the OP with adding anything beyond what was asked.
Guys, I did not read the question that way. I fully agree with Gar here. It's a bad question and there is nothing wrong to point out the actual correct answer to the OP.This part of your analysis is in conflict with the information given in the question. The 40A measurement occurred while the appliance was already in series with the 0.5 ohm splice.
That is "An appliance draws 40 amperes when used on a circuit." is referring to the particular circuit further described, not some other idealized circuit. I.e. it means "There's a circuit. An appliance draws 40 amperes when used on that circuit. . . ."
Cheers, Wayne
I don't see how it is possible to read "An appliance draws 40 amperes when used on a circuit. A bad splice is discovered on the line at the appliance on one of the phase conductors." as not meaning that the 40 amp measurement was taken with the bad splice in place. Care to expound?Guys, I did not read the question that way.
I am very sorry we dont agree. Similar to what bill Clinton said, it depends on what the definition of "a" isI don't see how it is possible to read "An appliance draws 40 amperes when used on a circuit. A bad splice is discovered on the line at the appliance on one of the phase conductors." as not meaning that the 40 amp measurement was taken with the bad splice in place. Care to expound?
That reads the same to me as "An appliance draws 40 amperes when used on a circuit, on which a bad splice is discovered . . ." Or "A circuit has a bad splice. An appliance on the circuit draws 40 amperes when used. . . ."
The last couple options are clearer, but I wouldn't say the original wording is unclear.
Cheers, Wayne
So I can agree that the question wording is not as clear as it could be. But I would say in the above you are reading something into the question that isn't there.I knew the the bad connection itself would change the current draw of the appliance, and figured they were giving the "normal" draw.
Ok fair enough. I would much prefer your suggested wording: "An appliance draws 40 amperes when used on a circuit, on which a bad splice is discovered . ."So I can agree that the question wording is not as clear as it could be. But I would say in the above you are reading something into the question that isn't there.
And of course as a meta issue, if you assume the 40A measurement is for "normal" operation without a bad splice, the question is unanswerable, as the supply voltage isn't given. So as a test question, the meaning has to be that the measurement is with the bad splice in place.
Cheers, Wayne
Of course it's a 240V range. What else would it be?FWIW, I first figured as the 240 range drew 40 amps. Did the math for resistance of it and added a .5 ohm resistance in series. Then VD and wattage for both. Nothing was right. Backed up looked at what was given, and added where in the heck did I get range?
Ohm's Law states that one volt is capable of forcing one amp through one ohm.
"Watt's Law" states that one volt across a load of one amp will produce one watt.
