ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician
Then we agree, NEC liberty with voltage drop never permited mixing Nominal voltages, or violating listings, much less local codes and job specs.iwire said:Ramsey as complicated as you like to make this the NEC does not control voltage drop except in the two Sections I posted.
Anyone advocating 100% v-drops for general purposes --as an NEC liberty-- should be spanked, at least by equipment listings, if not publicly flogged with vegetables and other nearby rubbish. Should the need arise, I'll be happy to provide more spankage. :twisted:iwire said:Your allowed 100% voltage drop unless there is a local code that says otherwise.
If I proposed novels of code I believe you would read every line, and your engagement at every point would be my pleasure. :twisted:iwire said:Again you want to write a novel thankfully you do not write code sections, the NEC would be ten volumes :lol:
