Our company is installing outdoor lighting from a large manufacturer. They have refered to the lighting as "277volt three phase". We clarified "you mean 480volt three phase?". And they insist on using the terminology of 277volt three phase. The poles came in and have 277volt ballasts. Two ballasts per phase. The question is, "is it appropriate to calculate voltage drop at 277 or 480 volts"? All three phases are terminated on a circuit breaker in a control cabinet in the base of the pole and each leg then is wired to two ballasts each with the neutrals coming back to the common neutral lug.
