Your inquiry is not clear. Need SLD. And again, etap uses load flow algorithm, which is an iterative process. Even if you use "exact" formula, it will never come close. Load flow is a lot more "exact" than the "exact" formula. I have been saying this and you are still insisting to prove it otherwise. Never compare it in the first place.
Sent from Mars
Thank you rian0201 for your interest.
Voltage drops behave different with constant power loads than with constant impedance loads. Such that the known formula seems to be more accurate to constant power loads, and surprissingly different with constant impendance loads which current increases when the voltage increases... it would not be only a ETAP matter.
Regards and thank you all for your kind and very useful attention in this forum.
