powerqualitycc
Re: Voltage Imbablance
Nearby capacitor banks have been known to cause bus overvoltage trips on drives. When the capacitor closes in there is a momentary short circuit (microseconds) then a ringing transient will occur (usually only lasting about 1/2 cycle). This is normal to the operation of caps and a 3% line reactor in front of the drive will dampen the problem. To verify this you would need a power quality analyzer that is capable of capturing waveforms with at least a 64 micro second response time.
The power quality engineer should be able to tell if you have a bad neutral connection if the connection is upstream of the monitor. Otherwise it was most likely an event on one phase of the 3 phase distribution system. This will cause the other two phases to swell, momentarily while the fuse blows and opens the faulted circuit.
