Hello.
Most recently I've been reading here and there about stray voltage and possible degrading neutrals.
Well I "think" I finally ran into it.
Went to check a 240v pool pump that's not working.
The time clock is 208-240v and the pool man say's he's been have problems with this 240v motor (been burning out ??).
All the exterior wiring is down low.
At the external time clock/motor, It's all rusted up. there are 2 boxes against an outside wall before the clock to the motor (1 gang fs).
From the first box there's a pvc conduit feeding the second box (2nd box has switch to clock/motor) and a conduit going out of the bottom somewhere (I kinda felt by sliding/squeezing my hand down in there).
I can't get to the first box at all as someone built a planter in front of it. At the second box (which also has the planter in front of it) I was only able to get to enough to pry and break off the cover.
It looks like a old single pole switch as one side I can see has no terminals on it and I can vaguely see a red and a white conductor in the box (thhn).
It continues from that box to the time clock thru pvc and sealtight (partly buried and not sure if there was/is a black wire) and in the time clock is a red-white-green.
At that clock location, I'm reading ~ 109v red to white, ~ 109v red to green, 20v white to green.
The service is overhead, to a 400a ct cabinet, through and 2- 200 amp panels.
The voltage at the panel is phase to phase ~ 219-209. Hot to neutral ~ 110-98.
So I think the pool pump never had the 240v as the pool man says it may have.
And Voltage is low.
My thought is to bring a new circuit ( 2 pole gfci protected) to the pool pump,
and safe off the existing circuit at the 2nd switch location and leave that circuit alone (as I don't know what else if anything the existing circuit is feeding), or maybe scope it out some more (?).
As far as voltage, is it low at 220-110 (and lower)? Should I get in touch with the power company?
My neutral and ground question.
At the existing time clock location, the 20v neutral to ground. Why is this?
Wouldn't testing those wires be the same as holding my tester on the neutral/ground terminal bar? Or, am I assuming that the ground at the pool time clock is going straight back to the panel bar, but it may actually be finding a different ground path (and also the one going back to the terminal bar)? Is that why? Does it have anything to do with a Bad utility neutral?
Thank you
And Voltage is low.
Thank you
