I was awarded a job that was doing panel changes and adding heaters to a 62 Unit apartment complex. There is a total of 4 building and each one has a meter stack. The problem that i am running into, is that there is about (5) units that have 90V from Neutral to ground, 120V Neutral to Phase A and Phase B. We have turned off all the breakers in the unit and there is still 90V to ground. Pulled the neutral out of the bar and suddenly all the lights work????? Neutrals and grounds are isolated at Unit panel. Has anyone ran into this issue before? My only thoughts are a loose neutral in the meter stack?
