Wow we have many 240v high leg deltas.
Bet you've never seen a high leg on a 480v delta, though.
Yea I would agree with that but other that fault protection of the other two phases and many less expensive I'm still not seeing why.
No but many ungrounded delta's. And it is amazing we have all the proper fault indicators installed many that are showing faults but try convincing management that this needs taken care of. There reply is well everything is still working fine. Yea I bet these guys are the same guys who keep driving there car when the oil light comes on.:wink:
Someone, your immediate supervisor or the highest authority (electrical superintendent?), whoever it may be, needs to find where the problem is, present this case to the management, and convince them of the problem, what could happen, and what repairs needed. It will only work fine for so long.
I called Poco on the cell phone while I was looking at the bank, they verified, and I looked at the connections "no intentional ground" only to the tranformer tubs, the bottom side of the lighting arresters, butt wrap, and service drop tension wire, was the only connections. ..
However afterwards I checked the line side of the meter socket and found 150k to ground from phases to ground
