drktmplr12
- South Florida
- Electrical Engineer
seems like everyone has ideas on how to change the set-up. understanding step-up step-down is not ideal and OP has done due diligence, and decision makers said make it so.
Are these standby emergency power or prime units used as the only source of supply for the loads?
If standby, after a power outage, transformers rarely have time to de-saturate before the generator is turned on. Transformer inrush is highly dependent on several factors. Without going into an exposition-Here is some reading material. That said, Generator control systems are much smart than they used to be-and it is highly dependent on the type of engine you get (diesel is assumed) and the electrical characteristics of the generator, coupled with the transformer characteristics.
Personally, I would run the setup (providing specifically the transformer particulars and whether it is a prime application) past the generator MFR (if not already selected, run it past whoever you think would bid) to be sure they understand the operating conditions and the GENSET being supplied can perform as expected from day 1.
