Landscape lighting transformers transform house current to a range of voltages from 12 to 22V. Since there is no regulation circuitry, any variation above or below 120 V will cause a proportional rise or fall on the low voltage side. This can be critical since low voltage halogen lamps have a narrow acceptable voltage range (10.8 to 12.0V).
Does anyone have information on the ranges of house voltages likely to be found? Also, how much voltage drop could be expected during times of high energy use? Also, are voltage spikes common? How high can they go, and for how long?
Lastly, is there an inexpensive piece of equipment that can record voltage over a period of time?
Thanks.
Thanks.
