How would a dialectric test be performed on a jack assembly that does not have any provisions for a ground? The jack assembly consists of 3 prongs encased in an insulating plastic material. I would typically approach this as test each line independently to the ground prong, and then tie all the lines together and dialectric test them all to the ground prong. Without a ground prong, or any kind ground present on the assembly, how can a dialectric test be performed?
Would I only be able to test between individual line conductors? For example, instead of applying 1500 VAC between L1 and Ground, I would just apply 1500VAC between L1 and L2, and check for any current coming back on L2?
