Looks like a 240 delta where the C phase is either faulted to ground or (badly) intentionally grounded
What is the information on the transformer?The service is connected to a transformer feeding a panel with a neutral . Wanted to see if a generator can be connected with a manual transfer switch .
If this is the case, something is definitely wrong. 240V delta would only have a Neutral if it were a "high leg" system, which is usually B phase, so A-C phase is split with a grounded center point to make 120V from A or C to N.The service is connected to a transformer feeding a panel with a neutral . Wanted to see if a generator can be connected with a manual transfer switch .
