I got a 60% on it, barely failed it. But I have some questions about the test.
I had 2 dwelling unit calculations that I'm unsure of due to the test wording. Both of them did not list a dryer but did not mention omiting laundry loads like two other multifamily questions. I assumed that I should include the laundry circuit and omit adding a dryer as it was not listed as a load?
On one of the questions I had two ranges listed at 8kva each. One in each side of a duplex. I used a 65% demand factor off Table 220.55 Column B. 16000w x .65 = 10400w. Did I do that correctly?
I'll be back in a couple weeks to re-take that section. I need to clarify that dryer/laundry issue before taking it again. No way am I going to risk not passing it again based on vague test writing.
