I recently installed a few ELV dimmers with LED tape, but the dimmers don't work. Everyone that I have spoken with from Lutron and the lighting distributor have said that there probably isn't enough load to register in the ELV's. There is about 15' of LED tape per 60W driver, and there is no way to load them both together now. Also, there are a set of Recesso LED direct wire pucks (set being 8) which dim, but do not turn off with a Lutron Maestro dimmer. To make matters worse, the switches in question are all Palladium, from the Satin color options of Lutron. If anyone has a solution for me, I'm all ears! I was thinking of some kind of inline resistor, but that just seems, sketchy, and also read a little bit about some kind of capacitor setup that is factory made for about $300 a pop. I'm finished throwing money at this guy's crazy fantasy, so anything that costs $300 per unit is out. So barring a miracle from you guys, I'm down to some sort of resistor circuit card make up, or eating the cost of 8 ELV Dimmers ($160/per), and installing single pole switches.
Thanks in advance,
Josh
Thanks in advance,
Josh
