romex jockey
- Vermont
- electrician
guess i'm old school then....~RJ~
For situations with more than three conductors - particularly 14 and 12 AWG general lighting/receptacle uses, I do prefer the multiport devices over twist on devices, but will often use them with two and three conductors as well.
Do not reuse a twist on when your wire combination is smaller than the original use - connector likely been stretched by previous use and won't hold as well as a new one will.
I have little problem reusing a twist on if putting same conductors back into it that it started with, say you are temporarily opening a connection for troubleshooting.
Y'know, I've always wondered why stuff always loosens with vibration. Why doesn't it ever tighten?.... I can't tell you how many times I've seen a screw on wire nut that has come loose from vibration.....
Oh.... it's been done on more than one occasion :- )How can you make a splice with one hand???
Pressure in the wrong direction to make it get tighter.Y'know, I've always wondered why stuff always loosens with vibration. Why doesn't it ever tighten?
