Apparently this is not nationwide. Thanks for filling in my blind spot.Illinois has “Supervision.” Basically, you admit to the traffic offense and if you don’t get another citation for a period of time (usually a year) your record gets cleared.
A condemned electrical inspector could demand to see the electrical permit and inspections first.Straight to the electric chair where you will experience first hand how AFCIs don't work.![]()
We have something similar here called an ACD (adjournment in contemplation of dismissal), but the courts just don't hand them out, you would typically need an attorney and it will depend on the offense and the circumstances and how strong are weak your case is, i.e. if you admitted to doing it or not More likely traffic infractions get reduced to "failure to obey a traffic device" which is no points and a fine.
Its time for me to insert the variable...Here, it’s almost automatic if your record is clean. If you have prior violations on your record, it’s closer to what you describe.
GFPE is used over 1000 Amps.Straight to the electric chair where you will experience first hand how AFCIs don't work.
No need for actual liability, to cause property owners a complete loss.it's not an issue of hackness so much as a purely business decision as to whether I want the supposed liability
The Original Post was about waivers on AFCI ... So, I am going to create a new thread on camp fire, "Why I Hate Traffic Tickets".
If it happens within a month or so of installation, maybe.I prefer no charge for the first service call, because I might have made a mistake in the installation.
If it is an installation subjected to inspection, your inspector may or may not think AFCI's are a good thing but if he is doing his job correctly he shouldn't be approving the installation if code requires them regardless how much him, the installer or the customer is against having them.If an educated customer came to you demanding that you not install AFCIs, then the waiver might help. Basically if you are doing everything you can to get the AFCIs in but the customer isn't having it.
Say you did an installation at my house, knowing that the AFCIs would be pulled when you left, so you install regular breakers so the non-professional isn't swapping breakers.
But if the AFCIs are not installed in order to reduce your bid, you are essentially encouraging the customer to accept a below standard installation.
Jonathan
