The general requirements for GFCI protection of 120 volt 15 and 20 amp receptacles is located in 210.8(B).
Chris
So when you close the door of the walkin, are you still in the kitchen?
Does a 15 amp outlet in a walk in cooler need to be GFI?
If you're in a bedroom closet, are you still in the bedroom? (I say no, by the way.)So when you close the door of the walkin, are you still in the kitchen?
I can't tell whether you're ticked off at her or us. I also can't help but wonder why you don't have an NEC at your disposal.I didn't know if it should be GFI or not so I called my shop.
The only one in was my sectary and told her to long on to MIKE HOLT'S code forum
and hopefully for a quick answer. The response I got was look at 210-.8b
I did not have a code book no the job. I consider this a lame answer why not respond
to all post with ITS IN THE CODE BOOK.
Isn't that kind of lame?I did not have a code book on the job
Okay, "ITS IN THE CODE BOOK" You were given a proper code reference to a question and you complain. You could have asked that someone quote the reference if you needed it..
I was on a job today installing lights in a restraint.
the owner asked me if I had time to install a 15amp outlet in a walk in cooker.
I would say most likely they want it for heat tape so it needs to be on a Equipment rated GFCI ( breaker) If its for general purpose, a GFCI would nt hurt given the location even if its not concidered the "kitchen" the inspector probably wuold enforce it
17 replies and no one wants to say yes or no. WHAT DO YOU THINK?
You have to remember what you find here is opinions. Most often opinions of experienced, trained professionals.I was on a job today installing lights in a restraint.
