Re: wall space
I have learned so much from this forum and yet am amazed that things that I take as "common" sense become topics with 40 - 50 replies. Our job as an electrical professional is hard enough without reading "gray areas " where there are none. Steps are steps and walls are walls
First of all, if you don't feel this type of topic is up to your standard and gets too many replies, don't add to the numbers by replying.
Second, "common sense" common sense tells me that wether you call this a step a wall or anything else, it
WILL BE USED AS WALL SPACE . As I posted earlier we see this particular set-up in a lot of our homes, I've gone back for service calls plenty of times, and have seen not only lamps but E.T. centers against this so called step. Where do you think they get there power from. "Common Sense" tells me that I should put an outlet in, anywhere I know it will be needed. If I have to use your so called "gray areas" of the code to get it done,
SO BE IT!
As far as cutting the outlet in. Have you ever heard of a floor outlet? Some of the models have a floor outlet in them, but it's an extra. It shouldn't be an extra it should be installed right away, and there should be 2 of them.
As far as the home owner calling in an electrician to add an outlet there later,
GET REAL . After just moving into your new $200,000 house, who is going to pay an electrician $50/hr. to fish a wire from one of the existing outlets and add an outlet. "COMMON SENSE" tells me there going to send there husband to the nearest Home Depot, to get themselves a nice #18 extension cord, take that cord, lift up on the carpeting a little bit, tuck it under there nice, presto an outlet.
As an "electrical professional" I'd think it's my job to prevent this from happening.
Binney!
