G
Guest
Guest
Re: Walls and Wiring
Regardless of any requirement, most platform type framing in theory does provide a 20-minute rating. It would be prudent, even if not required, to try and maintain that 20-minute rating whenever possible. You may not be bound by fire-rated foams, but you may reap a benefit.
If there is any balloon framing, there would have to be blocking at each level to create a 20-minute rating. Any holes in those blocks would have to be sealed to maintain the 20-minute rating. There may be other weak links in the wall assembly that undermine the 20-minute rating-- and no amount of foam or sealant is going to make those go away.
The home center foam (expanding type or non-expanding type) will create a draft seal, but it might not maintain the 20-minute wall assembly.
In summary, I personally would strive to maintain the 20-minute rating even if not required. 20-minutes isn't much, but it's better than nothing.
