- Tennessee NEC:2017
- Semi-Retired Electrician
If a warehouse has several rows of lights, all are around 20' up, where would you place occupancy sensors for each row, or couple of rows?
Voltage is either 120V or 208V.
Should the line voltage be used at the OC, or should contactors be used?
Would any additional OC be needed besides one at each end of the row?
What type sensor should be used?
Should the OC be placed up high, or low?
Management just wants lights to be off if no one is working in a particular isle.
Also would like to know if there is any OSHA violation in having lights off in a warehouse if workers are present?
