Designer69
Please see the attached Load Calc. and corresponding riser.
Can you check to see if you agree with the approach? You don't have to worry about the math, just that the approach makes sense. (I did it mostly by following the approach in Appendix D Example D3(a), since Article 220 is so confusing)
And that the corresponding riser looks ok... One thing I'm not 100% certain on is the 30A breaker protecting tenant 100A MLO panels.
Try this link since the the attached picture is not clear.
https://ibb.co/dBhAUS
Thank you! I appreciate your help.
