OldBroadcastTech
- Western IL
- Retired Broadcast Technician
Here's my $ 0.02
'Back EMF' from the motor.
I have LED's in my office, and when I turn a fan from 'high' to 'medium' or 'low', the lights will sometimes dim for a split-second.
What happens is that the magnetic field in the fan motor collapses and generates a voltage opposite to the applied voltage ( THINK 'spike suppressor diode on a DC relay' for comparison), this opposing voltage generated is enough to dip the line voltage to make the LED 'stuitter'.
With the washer or treadmill referenced earlier, the motor(s) have a varying load, and generate an opposing voltage going from fully loaded to partially loaded.
How to verify ? I suppose you could plug the load into a large-enough battery back-up supply and run off that for a bit, although as a rule UPS's do not play well with motor loads.
