jst442
- Idaho/Washington
- Journeyman Electrician
I can't seem to pass the admin test. Today was the second time I've failed missing it by 1 question today. I ve studied and can do a one family and multifamily dwelling super easy and fast. The ones I think I got wrong are the 2 duplex questions, the motor load calculation and the manufacturer facility.
The 2 duplex questions I did them as a one family home and added then together at the end on the total VA. And seemed like none of the answers were close enough. So not sure if I do it as a multifamily or if there is a special code I don't see on a 2 family calculation.
On the motor load calculation it seemed very simple but my answer was way more than answers provided. The question was " there is a 15hp, 2-10hp, and a 5hp periodic 15min motor. All at 480. What is the feeder overcurrent device if using a inverse time breaker?" I got all the ampre for each motor and I multiplied the largest motor by1.25(15hp) and than did the deduction for the 5hp(90%) than added it all together than multiplied it by250%. My answers was way larger than all the answers provided.
Lastly is a non dwelling question (manufacturer facility) . The question was something like " 2 manufacturer share the same building, one building is 4000sqft with a 3hp pump, 1500w micro, 28 outlets, 15ft of show window, 15kw heater and 30a 240 ac. 4.5kw water heater.
The other unit was 15000sq ft, 40 outlets, 25 ft window show lighting, micro. 50kw heat. And some other ones I can't remember. Is there a certain way to do a 2 tenant building that I can't find? I did them as a separate and added them together just as the duplex family homes.
Thanks for the reply and sorry its so long
