pete m. said:...I believe that OSHA requires that electrical equipment be de-energized prior to working on it. I know that there are some instances that the equipment can be worked on energized by OSHA regulations as well....
That is real close to my understanding as well.
In our case, we are not working the medium voltage hot. However, my interpertation of the existing standards is that a voltage check of the bus to verify de-energized state and attaching a grounding spider are considered live work and require appropriate PPE
As for the 600V class, the only live work I am doing is troubleshooting controls inside MCC buckets, or installing a plug-in bucket. One does not have to be very far from the xfmr to have the PPE drop to Hazard class 2 or 3 - which isn't to bad.
As dlhoule rightly said, the management wants the down-time minimized. Even so, I've never had to attach a wire to a live 480V terminal. I'm not sure I can even think of a case where one would have to.
pete m. said:...If the person is truly "qualified" and had to work on a piece of energized equipment wouldn't he/she be asking about the arc-flash calc at that time prior to commencing with the work to assure that the proper PPE was utilized?....
I'd agree. I think asking those sort of questions is a mark of a truly qualified person. On the job I'm doing now, I have the techs asking and since I haven't seen the engineering firm calcs yet, I'm getting the field data and doing a calc. Are my calcs way conservative? Oh yeah.
pete m. said:...The requirement to label equipment in accordance with 110.16 seems to me to be an insult to the "Qualified Person". ....
Yes, I'd agree with that. The NEC required label seems pretty useless. As Jim Dungar said, "However regardless of what verbage is chosen, I would not want to explain why my label format did not correspond to a standard like ANSI Z535. " As I recall, that's the format we're using on the perminate labels. Again, as I recall, it has the approach boundaries, incident energy, Hazard Class - significantly more useful than the NEC required label.
carl
