I have a ductless unit on a compute room wall, the owners would like a water sensor in case the condensate pipe becomes cloged. The typical water bug (wb-200) will not detect distilled water nor de-ionized water, Is the water that is extracted from the air distilled or de-ionized ? I want to tie this sensor into a 12 volt security panel form 24 hour monitoring, A typical sensor for a pan installation that shuts down the unit will not work because they are 24V, and i am not even sure the ductless unit has constant power in side.
Please advise, Thanks
