dellphinus
- Southern Illinois, USA
Looking for some ideas.
home less than 1 year old
200 amp Siemens panel.
4 20 amp AFCIs in the bottom four spaces in the panel.
Panel mounted 1/2 inch off concrete basement wall.
PVC conduit exits top of panel, LB, through rim joist, LB, into bottom of meter base.
Twice now, during extreme temperature drops (50-60 degree weather to near zero in a day), an AFCI has tripped.
First time, I pulled the AFCI, swapped a known good one in, and it reset and held. Figured it was a failed AFCI and moved on.
Second time, as I pulled the AFCI, it drained a quarter to half ounce of water out of the AFCI. No water outside the box,, some on inside bottom of box, and some of the copper bus bars were wet. Some moisture in between the non AFCI breakers. I originally thought it was warm, moist basement air condensing when coming into contact with cold outside air via the conduit (it was not sealed). But this wouldn't explain more water INSIDE the AFCIs? The only difference I can figure with the AFCIs is the circuit boards inside generating a little heat? Again, doesn't make sense to me- seems counter intuitive- the heat shoudl help prevent condensation?
Looking for some thoughts/experience. Cold conducted thru the feeders (copper) to the bus bars? Cold air into the panel thru the conduit? something else?
