bob j said:I'm wiring an instant hot type of water heater.It is single phase 120v and 3.5 kw. My question is- Can I use a 30 amp single pole snap switch as a disconnect even though the only ones I can find are only rated for 24 amps?
I've seen single pole 50A breakers so I would imagine they make a 40A.Dennis Alwon said:I have never seen a 40 amp 120volt breaker
chevyx92 said:I've seen single pole 50A breakers so I would imagine they make a 40A.
I agree with you on that one.Dennis Alwon said:Yes, perhaps they do but why would someone make a heater that was 120v and 3.5 kw. That's is just silly.
resistance said:I would like to see the specs. I know GE makes a single pole 40<<< I agree with the others, this is silly!!
7.5hp, 120V motorpeter d said:Let's see how many other examples of when we've needed single 40's we can come up with in this thread.
:grin: Oh boy! If I were that guy, I'd have told the instructor that I bought them at Home Depot, and they sell them there every day. :grin:brantmacga said:Apparently, this guy did work on a military installation in florida and they were custom ordered for a job there.
mdshunk said::grin: Oh boy! If I were that guy, I'd have told the instructor that I bought them at Home Depot, and they sell them there every day. :grin:
Thank goodness! I'd hate to wire a whole house in #8, even if I only had to install four GP circuits.mdshunk said:Not too many uses for single 40's.
Dennis Alwon said:Are you sure this is a 120 unit. 3.5 kw at 120 volts is 29 amps. You then need to multiply by 1.25 and you would need a 40 amp circuit 120v. I have never seen a 40 amp 120volt breaker
I didn't think an instant hot water heater fell under the heading of continuous load, because it isn't a storage type heater.422.13infinity said:How does the 1.25 factor come into this calculation? Are you considering an insta-hot a continuous load?
