OK Sparky 93
- Iridea14Strat
- Electrician
if a water pipe is used as an electrode, would it also be required to fall under the bonding code requirements. This I don’t know if I am thoroughly clear on. If it was co formed that a GEC did go to the entry point of water pipe, would it be that you would only make a jumper to the hot side of a water heater, provided if everything was copper throughout?
