karl riley
When metallic water systems exist, the required grounding to the pipe allows some neutral current to return to the transformer through a neighbor's neutral and vice versa. For different reasons this current on the water system can be considered objectionable.
It is sometimes stated that this connection is good because it provides a backup for the neutral if the service neutral opens. Can anyone offer reasons why this is good? Since I can see many disadvantages to using water pipes as backup, I want to be aware of the other side of the question.
The disadvantages as I see it are:
1)it masks a dangerous situation (open neutral) that needs to be fixed as soon as possible.
2) It puts current on conductors which were not designed to carry current and hence are unregulated by NEC specs.
3) It sets up a lethal situation for any plumber or water worker who separates a pipe carrying the return neutral (120V).
4) It causes high magnetic fields both from the pipes and both service drops.
5) The widespread use of plastic water pipes has not been connected with any safety issues I have heard about.
So now, how about the pro arguments. Anyone?
Karl
Karl
