Westchester/Rockland 4
A very importantant question. In the aftermath of the flooding in Mamaroneck, NY. The flood waters rose to over 10 ft, submerging the meters, and much of the electrical wiring and equipment, including panels and breakers. What is the ruling on submerged wiring and equipment? The water is considered contaminated by overflowing sewers and such. Should all the equipment and wiring be replaced or is it acceptable to just clean out the enclosure amd replace the breakers and wiring that is not rated water resistant. This is creating much chaos, as there are 4 inspection agencies here. Each one has a differant view. Some are telling property owners they only need to clean the enclosure and replace the breakers, while others are saying take everything out and replace it all. case in point: one property owner pays $10,000 to replace his entire service, because one inspector says to replace everything, while a multi family dwelling next door only replaces the breakers and feeders and cleans out the enclosures with an oil based solvent, as another inspector requests. There has to be some sort of norm in this type of flooding condition... Should the state make a ruling as there is nothing on the code that covers flooded equipment. The property owners are in an uproar....HEEEEEELPP!!!!!
