water well grounding or bonding
i have kinda of instering question about water well with steel casting go in ground will this treat like a ground rod ?? [ i know most place requred at least 2 ground rod for grounding puropse] and have to sized by per nec with main breaker rating ??
i got part of answer there but not explain clear
thanks for your time
Merci, Marc
Re: water well grounding or bonding
Marc -
250.52(A)(1) allows a metal well casing to be used as a grounding electrode if it meets the criteria of that paragraph.
No need for ground rods when you use the well as an electrode.
