B billscott New User Location Jersey Shore Pa 17740 Apr 25, 2014 #1 Can l run romex in the same hole in joist with water lines in a garage
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Apr 25, 2014 #2 Yes. Welcome to the Forum.
tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician Apr 25, 2014 #3 Can you run rigid metal or MC cable in the same hole as a water line? If the answer is yes, then you can also run NM as they are all chapter 3 wiring methods.
