Fulthrotl
~Autocorrect is My Worst Enema.~
- E
gotta rack coming into a building, and water is following the conduits into the
building, and dripping off at the first trapeze. six 4" conduits, in a 3 X 2 array,
about 5' below finished grade (lawn)
it's a bunch of water, enough that one solution that was proposed, was
to make a catch pan with a sump in it, and a pump to push the water to
a drain.... looking at maybe 20-30 gallons a day..... :-( more when it rains.
a contractor came and gave them a bit of $90k to dig it all up and
replace it, back to the vault. facility running on a generator for 4
days, etc.
i've fixed stuff like this before, but i'm wondering if anyone's got a better
way than what i've used, which works, but is kinda sucky to do.....
first, i bush the concrete out 3" deep, around the conduits, and put a form
up to the wall, then use hydraulic cement to seal it back up.....
then i go open up a 4' hole next to the building, and clean the pipes up,
and get everything nice and dirt free, then i have a hot mop guy come and
tar the whole thing, just like a shower pan, then i backfill with sand, and
call it a day.... i've done it half a dozen times over the years, and it always
works.
anybody use anything else to fix leaking penetrations below ground that
isn't as icky a process as what i described...?
thanks in advance.
randy
days, etc.
works.
thanks in advance.
randy
