Are weather heads in a service always required?
I've seen no weather heads installed at the shore on SEU, and I'm guessing because of the effects of the salt water (air) but what about the rest of the metal components, pan, straps, connectors ?
If this is the reason, even with no salt in conditions, why would a service head be required in other areas ( with proper installation to not have water run down the inside of the sheath) ?
Reason I ask. I'm in Jersey and I always pass a commercial building with 3" (? Maybe larger) running horizontally across the top of the building then ends in a 45 pointing down to where the conductors come out to a drip loop.
I see no problem with it but is a head nessasary to satisfy code?
Just curious.
Thank you
Just curious.
Thank you
