I believe you, but I have yet to see a 3R junction box that came with instructions or white papers of any sort. I'd be most interested to know what brand that might be. I looked over the few I have on hand when you typed this a while back, and none of mine seem to have any such restriction. I even read all the little stickers. If there's a certain brand with this wacky restriction, I'd like to not buy that brand if I can help it.dezwitinc said:Be sure and check the manufacturer's info that comes with the box.
Sure, that's the way to fly. Even with a Meyers hub, I like to put a light bead of silicone on the sealing portions of the hub fitting before I make it up tight. With these PVC weatherproof boxes, you need to drill a couple of drain holes too, since the manufacturer doesn't know how you're going to orient the box.infinity said:Although a sealing locknut will satisfy the code requirement IMO a Meyers hub would be a better installation, but at a greater cost.
mdshunk said:Sure, that's the way to fly. Even with a Meyers hub, I like to put a light bead of silicone on the sealing portions of the hub fitting before I make it up tight. With these PVC weatherproof boxes, you need to drill a couple of drain holes too, since the manufacturer doesn't know how you're going to orient the box.
kpepin said:Did you know unused openings in bell boxes with the plug that is supplied with them installed is not raintite? I saw the note stamped inside of a box on Friday that said, plugs are only raintite if silicone is applied. Never noticed that before.
mdshunk said:Even with a Meyers hub With these PVC weatherproof boxes,
You run into the same problem when you're trying to put a bushing on a PVC terminal adaptor when you're running conductors #4 and larger.chris kennedy said:2" PVC into a Meyers hub into PVC J-box?
How do you bond the hub? I haven't seen a Meyers hub that had enough thread left for a bond bushing.
mdshunk said:You run into the same problem when you're trying to put a bushing on a PVC terminal adaptor when you're running conductors #4 and larger.
