zbang
- Roughly 5346 miles from Earls Court
The NEC current ratings are based on heat dissipation and the insulation (fire safety), so forget about all of those for this application. The things to look at are resistive and minor inductive losses (ignoring any "skin effect").
Work from the current back through the resistance to voltage loss and decide what's an acceptable level. Example, 10g wire is about 1.1 ohm/1k-ft, so a 50 amp current will give about a 2.4v drop (probably way too high). Maybe 4g will do the job, you'll have to run the numbers. And if this is not an "audiophile" application, things are a lot easier.
