Paul McKeown
Am working on a renovation of a crappy 3-story walkup, aluminum wired.
Supposed to be just replacing all the lights, switches and receptacles with pretty stuff as the owners want to sell the suites as condos. Running into a lot of loose wire nuts and very strange voltage readings. Common problem is open neutral in ceiling box ahead of or downstream of the octagon box I?m at. When I check the light, it doesn?t work and when I check the voltage, line to neutral, it?ll be something weird like 84 volts (120 line to gnd). Any ideas what might be happening to cause the odd voltages. Problem always resolves when I find the loose neutral.
Sorry if I sound dim....I normally work in a heavy industrial environment and haven't run into anything like this before.
