edlee
- Western Massachusetts
I roughed in a Panasonic bath fan and now am trimming it out. It is designed to run continually at a low speed and when someone wants to use it as a bath vent then they hit a switch and it boosts it to high speed. So the wiring consists of bringing a constant hot and neutral to the fan and from the control box on the fan dropping a switch loop down to the wall booster switch.
Problem is the switch loop, which is integral to the control board, switches the neutral. Not the hot. When I roughed it in I called Panasonic and asked them about this and they told me the wiring diagram was correct.
Fine. Since the homeowner wants a timer on the wall I had figured I would just put in a 2-wire spring-wound timer. But the builder wants an electronic push-button timer. I told him I didn't know if I could make it work.
I tried a 2-wire PB timer and while it started the fan, it wouldn't time out and shut off. I tried a 3-wire PB timer, reversing the polarity (brought hot to white wire and neutral to black wire) and, guess what, it works.
Question is, would wiring in a timer reversed polarity be a reasonable and safe solution? Or simply reversing the polarity of the fan wiring itself? I don't really like it!
The circuit BTW is AF/GFI protected.
