kwired
Electron manager
- NE Nebraska
- EC
I suppose you could thread the fittings together and then just tack them.... it's not like you have to weld the whole thing up so it doesn't leak like it was some sorta gas pipe.
I'm curious how you'd weld in an atmosphere that was so explosive that it prompted you to weld your fittings together to prevent them from arcing on a fault.:huh:
At initial construction the explosive atmosphere is not there yet. Afterwords there may be ways with positive ventilation and strict procedures of how to do so, can't say I know for sure but see it as possible.
Have seen welding done on live gas pipe, they light the gas before welding, when welding a tap to a live line or other similar operation. When the fire goes out it means the leaking gas has been sealed off and there is no more gas to feed the fire.
