J j87 Member Dec 7, 2004 #1 Is there a requirement that a welding receptacle and plug be mechanically locked in before use, either through the plug being threaded onto the receptacle or a built in interlocking device? Does the plug have need something to hold it in place?
petersonra Senior Member Location Northern illinois Occupation Semi-retired engineer Dec 7, 2004 #2 Re: Welding receptacles I have seen plenty of 120V welders that come with a regular 15A plug on it. Nothing unusual at all.
J j87 Member Dec 7, 2004 #3 Re: Welding receptacles Thanks for the reply. I should have been more specific. This is a 480volt receptacle
petersonra Senior Member Location Northern illinois Occupation Semi-retired engineer Dec 7, 2004 #4 Re: Welding receptacles I looked in article 630 which covers welding equipment and saw nothing about receptacles at all.
tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician Dec 7, 2004 #5 Re: Welding receptacles It may be local code or practice. But with 480 its not a bad idea.
