Am I looking at the correct chart when sizing wire for a well pump? I'm looking at 430.248 and using the 230 volt column. The well in question is 5 horsepower. Would I be correct in using a 10-2 NM-B as the chart claims that the full load current is 28 amps? The well contractor is saying that it needs to be a minimum 8-2 NM-B. I'm not sure where he is getting his calculation from. This is at a residential home with a 200 amp single phase panel.
