kwired
Electron manager
- NE Nebraska
- EC
Not sure what you are trying to get at here. Any well will have higher pressure the deeper you go, but the amount of power needed to lift the water only depends on how high above the "draw down level" you are pumping the water, whether your pump is 10 feet or 1000 feet deep. Pipe size will impact flow rate but not how much lift power is needed until you get above the draw down level.The water in the 1000 foot layer may be under quite a bit of pressure, such that the static water level is quite a bit higher. Think of an artesion well, which has water pouring out of the well casing after it is drilled.
