ptonsparky
Tom
- EC - retired
How often do the drives on a modern residential pump system cycle? Those with drives and not typical pressure switch.
I installed mine 14 years ago and bent over backwards to make it run longer than the 10 to 15 seconds it took to refill or bring the pressure up on the small pressure tank with shower and hose bib usage. Ten seconds between starts with about a minute run. From what I can tell, less than .5 hp most of the time. (1.5 hp). I have figured out that the sprinkler system relies on SFA to keep up even at 40 psi. Next pump will be bigger.
