electrofelon
- Cherry Valley NY, Seattle, WA
It is a fuse but I’ve never seen them installed that way. (Doesn’t mean much. I haven’t seen a lot.)
Zoom in and and you can see the ring for the hot stick.
Cheaper to install; no mounting. Used for sectional isolation.Ahh ok. Why might they be installed? Seems like they would be killing a lot of customers if they were opened.
Around here a disconnect that was designed/planned for is more rigidly mounted on a pole/structure. This kind of thing is used when in a pinch on existing lines and need to isolate something that doesn't already have a means for quick isolation.Cheaper to install; no mounting. Used for sectional isolation.
Customer count has to do with placement in circuit.
Manual operated switches with load break attachment:
https://www.sandc.com/en/products--services/products/omni-rupter-switches/
https://www.sandc.com/en/products--services/products/alduti-rupter-switches-outdoor-distribution/
Automatic remote control operator if desired:
https://www.sandc.com/en/products--services/products/6801m-automatic-switch-operator/
Recloser with microprocessor control:
https://www.eaton.com/us/en-us/cata...ontrol-systems/nova-three-phase-recloser.html
https://www.eaton.com/us/en-us/cata...-control-systems/form-6-recloser-control.html
To sub-sectionalize the line for repair. Or isolate the down stream problem so to re-energize everything upstream.
Its done all the time with either manual switches/disconnects or automatic equipment.
Here is an example of what I'm talking about:
https://www.youtube.com/watch?v=2VGs7FdrSIE
Most likely.Ok this is starting to make sense. So basically they are not installed "for the future" they were installed for repair and "left in place".
what are these things on distribution lines?
All the items you linked to are a type designed to mount on a pole or cross arm in a fairly rigid fashion.
The item in the OP is more of a non rigid "in line" item that goes directly on the overhead span of conductor, and then they cut the conductor, instead of mounting on a pole or cross arm. Advantage I would assume is it can be installed rather quickly when conditions call for that. Like I said when we had an ice storm several years ago, a lot of these were installed to isolate different sections so they can get the main lines up more quickly, then come back and fix those areas they isolated.
Most likely.
great video. That scenario is an example of them being for the future as a disconnecting means, not put in as a repair (although they might also use one for the repair).
You didn't note anything there, just posted a link that I never looked at until now.Already noted here:
https://forums.mikeholt.com/showthread.php?t=198717&p=2002706#post2002706
I posted what I did as an example of various devices that isolate and segment lines- either manually or automatically everywhere from a simple none load break switch to a vacuum interrupting microprocessor controlled circuit breaker.
