James L
- Kansas Cty, Mo, USA
- Electrician
Handy boxes are the choice of most guys here for furnace switch and receptacles on concrete
I stopped using handy boxes quite some time ago. I much prefer the 1900 box.
Always thought you were a half bubble off plumb!I stopped using handy boxes quite some time ago. I much prefer the 1900 box.
But I don't put the pipe in the center k.o.
I've certainly done that, depending on the job. Kudos for removing the device ears and adjusting the box ears.
Nope, #6x1/2 sheet metal screws. This method certainly seems cleanest if there's no reason why not.I've certainly done that, depending on the job. Kudos for removing the device ears and adjusting the box ears.
Are those 6-32s I see screwed into the wood?![]()
Agreed. And, the screw heads just happen to match.Nope, #6x1/2 sheet metal screws. This method certainly seems cleanest if there's no reason why not.
If you don't cut the ears off, the plate won't sit right.I've certainly done that, depending on the job. Kudos for removing the device ears and adjusting the box ears.![]()
Yup,
Most usually, there's a gap between the top of the microwave and the bottom of the cabinet.I try install the receptacle on the same side the MW power cord comes through the cabinet to minimize the space that it takes up.
Most of the time it's on the right side.Most usually, there's a gap between the top of the microwave and the bottom of the cabinet.
I drill the hole for the cord directly under the receptacle. Then after pulling all the cord through and fastening the microwave, I push all the cord slack back down into that gap.
Even on custom cabinets that are solid right where the microwave cord is, I'll drill some of that blocking out to channel the cord over to that gap
Yeah, it's on the right.Most of the time it's on the right side.
I hardly ever install the microwave unless it's solely a job that I'm doing.
Absolutely.I drill the hole for the cord directly under the receptacle. Then after pulling all the cord through and fastening the microwave, I push all the cord slack back down into that gap.
In this case I was upgrading an old kitchen from hood to MW. The cabs are Depot "Euro style" frameless so there's no space under. And I was limited both by how much slack I had in the cable I had fished originally and where the studs were. So there it went. I put them in the top corner to get the cords out of the way as much as possible even though if I put them on the bottom only the tall would see it.Most usually, there's a gap between the top of the microwave and the bottom of the cabinet.
Depending on your ducting route.....In this case I was upgrading an old kitchen from hood to MW. The cabs are Depot "Euro style" frameless so there's no space under. And I was limited both by how much slack I had in the cable I had fished originally and where the studs were. So there it went. I put them in the top corner to get the cords out of the way as much as possible even though if I put them on the bottom only the tall would see it.
What I have yet to figure out is ducting a MW/hood without a deathmatch. Done it twice and it's nearly impossible to attach the 6" round to rectangular adapter in there.
Its connecting the rectangular to the flange on the MW that's the problem. You can't get screws in there, and taping with foil tape is a bear. I've been running it out a soffit to the outer wall, so it could be rectangular up into there but I still would struggle with the 1st connection. And with the "tip up" wall flange mounting of the units its not like you can put on a 12" length and then install the MW.Depending on your ducting route.....
Top of a microwave is typically 3"x10" if I remember correctly. If you're ducting into the attic and out, you can go rectangle all the way into the attic, then adapt to round.
If you're ducting out the wall from inside the cabinet, you can go rectangle up to the top of the cabinet and cap it off. Then cut a round takeoff into the back side of the rectangle and go straight out without a direct adapter
The trick is to position the opening of the duct in the right place and level with the cabinet bottom or skirt, so the MW outlet will "plug" into it when you raise the MW. There isn't supposed to be any direct attachment between the outlet flange and the duct.Its connecting the rectangular to the flange on the MW that's the problem. You can't get screws in there, and taping with foil tape is a bear.
How can that be? You'd be leaking greasy air into the cab interior!The trick is to position the opening of the duct in the right place and level with the cabinet bottom or skirt, so the MW outlet will "plug" into it when you raise the MW. There isn't supposed to be any direct attachment between the outlet flange and the duct.
A. The flange should have a thin foam rubber gasket on it.How can that be? You'd be leaking greasy air into the cab interior!
